2014 prostar problems with oil pressure and abs module
Discussion in 'International Forum' started by Demonrogue, Oct 20, 2016.
  1. dom14
    dom14 Light Load Member
    66
    10
    Oct 18, 2016
    The oil is fine I just noticed it was a little low on psi but now I know it's just a low psi engine no lights or problems
  3. me myself and I
    me myself and I Heavy Load Member
    736
    312
    Oct 5, 2009
    vernon hills,Il
    My point was that it would have taken you less time to look up what's oil pressure should be, then to post here complaining that it's low.
  4. no love for a trucker
    no love for a trucker Light Load Member
    93
    26
    Jul 28, 2013
    Greensboro, North Carolina
    Me Myself and I why are you being rude. Brother it's no need either you give a positive comment or just move on.
  5. me myself and I
    736
    312
    Oct 5, 2009
    vernon hills,Il
    Rude? Dud took it to the shop over it, then he posts a question here. It takes less than a minute to find an answer.
    Positive comments? I prefer honest answer. But if you're A for an effort, ribbon for participation type of guy have at it.
  6. Lstrucking
    Lstrucking Bobtail Member
  7. Sumeet4682
    Sumeet4682 Bobtail Member
    4
    Hi, my international truck has exact same problem. When it’s stuck in traffic or moving very slowly it shuts down. The oil pressure is slightly less than 20psi normally when it happens. That inverted triangle light-ABS maybe-shows up and it starts beeping.
    Then we have to wait 5-10 minutes and then it starts again and doesn’t creates problem until it is moving very slowly in traffic again.
    My mechanics can’t diagnose this issue. Please let me know if you got it correctly diagnosed.
    The truck drives good has has more than 40psi while driving.
    Thanks in advance.
  8. Sumeet4682
    4
    Hi, my international truck has exact same problem. When it’s stuck in traffic or moving very slowly it shuts down. The oil pressure is slightly less than 20psi normally when this happens-That inverted triangle light-ABS maybe-shows up and it starts beeping.
    Then I have to wait 5-10 minutes and then it starts again and doesn’t creates any problem until it is moving very slowly in traffic again.
    The truck drives good has has more than 40psi while driving. Temperatures are never very high in this process.
    Thanks in advance.
  9. Sumeet4682
    4
    Engine is Prostar -2013
  10. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    So you have a maxxforce engine? What codes are getting logged?
  11. Sumeet4682
    4
    There are no codes visible as it happens on road and starts back in 5 minutes after waiting on the road.
    Dealersship say said they dnt have a code when they check.
    Only ABS inverted triangle light comes on and goes after 5 minutes and its good to go again.
    Somebody told me it might be clogged fuel filter.
