2014 Volvo D13, acceleration issues
Discussion in 'Volvo Forum' started by Pacman2018, Jul 30, 2018.
  1. Pacman2018
    Pacman2018 Bobtail Member
    I have a 2014, d13, 10 speed. When im loaded it feels like its missing, wont pull a hill and have a hard time picking up speed. If it flat ground, empty or bobtail it will get up and go. Engine light will come and go off. Dont know what code is cuz it goes off before i can have it checked. When in high idle u can feel a light miss. Had fuel filter changed and it seems to have gotten worse since i had it changed. Any ideas, please help.
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    It should store the fault. It's the only way anyone is can give you any advice.
  4. Northerntanker
    Northerntanker Bobtail Member
    28
    38
    Mar 30, 2018
    Sounds like injectors perhaps?!
  5. ReeferOhio
    ReeferOhio Medium Load Member
    596
    557
    Nov 29, 2010
    Those are known for injector cup issues. Have they been replaced yet?
  6. Pacman2018
    Dont know only be in the truck a month
  7. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    For Us 010 emission truck the fault code can be read with the cluster only when they are active but can be read with the proper tool anytime, you need more information before changing any other parts , i think.
    Ben
    Johny41 and Socal Xpress Thank this.
  8. high_roller_302
    high_roller_302 Bobtail Member
    28
    20
    Feb 9, 2012
    Canada
    It sounds like an air in fuel or head gallery pressure issue as the issue is only present under high load conditions. Have a shop perform a air in fuel check that basically involves fitting a clear line to the engine’s return fuel connector. If there’s air in it that resembles beer foam, I would think that you have a failed injector to cup seal. This is known as a “basic” test. An advanced test requires installing a series of other lines in various places to pinpoint the area of air introduction. But in my experience, if the return fuel is a foam, injector/cup sealing is a factor. The overflow valve at the front of the head can also give a similar feeling if it is unable to retain the proper pressure. Normal pop pressure is around 45psi. Hope this helps.
  9. 86scotty
    86scotty Road Train Member
    4,759
    13,053
    Aug 27, 2017
    Appalachia
    Are guys from Canada all born with an in-depth knowledge of Volvo engines?......or is it me?
