2014 Volvo D13 Starting Issue
Discussion in 'Volvo Forum' started by haider99, Sep 26, 2017.
  1. haider99
    haider99 Medium Load Member
    685
    108
    So recently I turned when I go from ON position to crank, it just clicks and nothing happens. I have removed and cleaned the terminals. It kept on doing this for a few time and on the display it would show that the Neutral is not dedected. I then unplugged/plugged under the ishift lever amd started the truck and it started fine.
    It then started to give ECU maintenance required message.
    Also, when i keep cabin lights on and try to start it, the lights would turn off for a few seconds.
    The batteries are good and my mechanic wants me to change started.
    What do you think?
    KB3MMX Thanks this.
  3. Bike rider
    Bike rider Bobtail Member
    48
    33
    Apr 11, 2016
    I work for a Volvo dealer, this is the comment from our Service Manager.
    The customer is right to suspect the starter will likely not fix the issue. Sounds more like the shifter itself especially if he unplugged it and the truck started. Could also be the battery disconnect switch, I've seen those act up in strange ways.
    Socal Xpress Thanks this.
  4. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    i would say it is the battery disconnect switch have seen this problem happen million times starter is not getting enough power.
    KB3MMX and Socal Xpress Thank this.
  5. shogun
    shogun Road Train Member
    6,075
    72,164
    Jan 23, 2009
    Doing a regen
    ECM maintenance typically is the ecm losing power for a few mins, it should go away on its own. Probably happened when you disconnected the lead and reconnected.
    KB3MMX Thanks this.
  6. haider99
    685
    108
    Which lead?
    Yes it goes away after.
    And correction: its ECU msg and not ECM.
  7. haider99
    685
    108
    So I should start off by changing the switch?
  8. shogun
    6,075
    72,164
    Jan 23, 2009
    Doing a regen
    It's typically the small lead on the front battery, about a 14 gauge red wire connected to the terminal. As long as you tightened everything back up, it goes away.
  9. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    you can just remove the cable from switch and bypass it altogether. just connect them together. and see what happens
    KB3MMX Thanks this.
  10. haider99
    685
    108
    Never got a chance to take the truck to the mechanic. Will be taking it tomorrow.
    When this issue happens and I crank it, there seems to be a spark behind the cut-off switch.
  11. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    need a new cut off switch
    KB3MMX Thanks this.
