Air is bunk works great. In cab sux. The temp doesnt change. Always blows semi cool. When I turn the defrost on it will actually warm the cab but if I turn it to feet, chest, anywhere other than defrost, very little air come out. I have to run my bunk ac on high to keep the front tolerable. I've read, possible blend door actuator. Where is it located? I see 3 or four under the dash. Does anyone have a diagram for the 579 ac? Getting pretty aggravated with it.
2015 579 air conditioning
Discussion in 'Peterbilt Forum' started by calvinbabb, Apr 30, 2020.
I'm wondering if the cabin filter is clogged up.
I change it every 6 months. So no. Also have cleaned the coils.
Flat Earth Trucker Thanks this. -
Im having a similar issue on my 2016 579. All vents works except the front vents. I checked the fuses and they all seem fine.
Im guessing its a blend door actuator, but there are 5 of them, so I have no idea how to figure out which one it is.
Theyre around $100 each -
I know there was a service bulletin from peterbilt on our years due to blend door failure but was for the doors themselves.
mhlvc Thanks this.
