2015 Cascadia Evo Electrical problems
Discussion in 'Freightliner Forum' started by Djstocks, Sep 20, 2014.
  1. Djstocks
    Djstocks Bobtail Member
    13
    Jan 30, 2014
    When I got my truck it had 180 miles on it, at 200 a check engine light came on saying "air intake problem detected, 25% derate" Ive taken it to the shop 6 times and they do a forced regen clearing the code and give it back to me. Only it comes back on 50 miles down the road. Now the truck has 20000+ miles on it and ill be driving down the road at 65mph and all the power cuts out and comes back on (sometimes) sometimes it does not so I am forced to wrestle the dead beast to the side of the road. I think the engine light, the fact that it never asks me for a regen and the random power loses are related but they might not be.
  3. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    most of the time it will do a passive regen. you dont want to have to sit and do a manual regen.
  4. Djstocks
    13
    Jan 30, 2014
    yeah I figured but the power going out when Im driving is my main concern.
  5. damutt
    1,126
    370
    May 6, 2013
    not sure if this helps. when it cuts off does the CEL (red AND yellow) flash then die? i had that happen and it was low on coolant.
  6. Djstocks
    13
    Jan 30, 2014
    Nope thanks tho. Everything just goes out, everything, instantly.
  7. damutt
    1,126
    370
    May 6, 2013
    hmm last think i can think of would be bad battery/crap connections? anything after that im of no help
  8. snowwy
    snowwy Road Train Member
    20,618
    13,340
    Jul 6, 2009
    YOUR TRUCK is too new for anyone to know. even the dealer. LOL.
    your still under warranty, let them deal with it.
    new trucks usually spend more time in the shop then on the road.
    GenericUserName Thanks this.
  9. Pahrump
    Pahrump Medium Load Member
    if it has a cummins take it to cummins ,,Detroit to Detroit,,,forget the dealer,, if it derates,,,disconnect the batteries for a couple mins,,it will reset the ecm when you reconnect the batteries,,,
  10. mattbnr
    mattbnr Road Train Member
    1,950
    837
    Aug 19, 2010
    Tama,Iowa
    Id take it to a dealer and have them check for loose connections. Sounds like a loose harness somewhere.
  11. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    reason why you should not have a newer emission truck. I prefer gliders with 12.7 detroit.
