I've been having a heck of a time trying to get this stupid Internationals ac working right.. The trucks leased from Ryder but the mechanics at this specific location can not or will not figure out whats wrong with it. They say well if it's not acting up while we have it we can't diagnose it.. So far they've replaced the filters and recharged the Freon in it. Problem is when its sitting it works fine.. It only has the issue when I've driven it for a couple hours. So the typical scenario with it is after driving for an hour and a half or so the temperature will drop down 15 or so degrees and the fan will also stop blowing as hard. also the air seems to get humid. If I turn the truck off for 30 minutes or so after starting it back up it runs fine again giving me another hour and a half or so before doing the same thing as before. Anyone have any ideas on what it could be?
2015 International AC problems
Discussion in 'International Forum' started by joseph1853, Aug 2, 2018.
I’ve read about people relocating the ambient temp sensor on their trucks or higher grounds and fixing their a/c problems
joseph1853 Thanks this. -
It sounds like it is freezing up?joseph1853 Thanks this. -
Update on my truck ac issue. I think it's finally fixed. After replacing all filters, cleaning the condenser coils, and freon flush they have found some loose wiring under the fuse box that was causing the compressor to stay on constantly causing the system to freeze up. Some kind of temperature sensor I think. I've had it for a couple days now and it is working better then it ever did. 4th times a charm lol.. Thanks for all the help.
