2015 Kenworth T680 Temperature Control
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by adabros1, Oct 21, 2018.
  1. adabros1
    adabros1 Bobtail Member
    Hey guys,
    I'm having an issue with my climate control I believe. When I turn it to the coldest setting, the clod air will blow from it. However when I change it to a warmer setting, there is no warm air that comes from it. Just regular temperature air. I have already replaced the dash control (F21-1028-2381), an actuator for temp mode (T6892003), and also a sensor-temp freeze (K7755001). It still does not flip over to heat. What am I missing? Has anyone else had this issue?
    Thanks
  3. Goodysnap
    Goodysnap Road Train Member
    3,791
    9,228
    Jul 12, 2017
    Are you certain that you changed the temp door actuator? There are 5 total actuators in the dash and they are all the same part#. The panel and temperature doors can also strip or break where they attach to the actuators.
    pushbroom Thanks this.
  4. Snaponfan1
    Snaponfan1 Bobtail Member
    16
    9
    Oct 22, 2018
    Goodysnap is on the money. It may be wise to get it properly diagnosed at a dealer using ESA. Replacing a blend door is a labor intensive job in a T680 or a PB579. You can possibly try resetting the CECU, but if the doors dont calibrate you have an issue. Are you sure you have good coolant flow in/out of core?, just wondering. But I would just keep throwing parts at it
  5. Snaponfan1
    16
    9
    Oct 22, 2018
    I meant to say, I would not just keep throwing parts at it(oops)
  6. AGY Guy
    AGY Guy Bobtail Member
    Texas
    I have a problem with a blend door Defrost/Dash vents, it stays on vents. I tested the voltage at the actuator plug and eliminated the controls. removed the actuator and tested it with a 9v battery as shown on utube and it was bad. replaced the actuator only to find that the blend door shaft was stripped out. I have tried wrapping teflon tape around the shaft, but the female side is to stripped out. can this be glued and then calibrated?
  7. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    There is a update to the HVAC software that is supposed to help with that issue of blend door being held to tightly. Might wanna get the update. It is TIB 01-073.
    pushbroom and AGY Guy Thank this.
  8. Goodysnap
    3,791
    9,228
    Jul 12, 2017
    The doors are common to break. Replace temp and panel doors and actuators. Dash removal is required.
  9. balliworld
    balliworld Bobtail Member
    26
    9
    Apr 25, 2019
    Can you please tell b where that dash vent actuator is located?I am having a issue with defrost dash vent.
  10. balliworld
    26
    9
    Apr 25, 2019
