2015 Mack Pinnacle Regen issues
Discussion in 'Mack Forum' started by K&G Trucking, Feb 8, 2021.
  1. K&G Trucking
    K&G Trucking Bobtail Member
    5
    Filters have been cleaned 3 times jetted twice in past year. Cleaned in November because went into Derate one month later would not regen again so they had filters jetted again. Already the truck will not regen when light starts blinking and tells me too I pull over and it will not do it. What else can be causing this? I’m tired of taking it to them and having my truck for week at time and not fixing the problem that keeps causing this. Has anyone had this same issue? If yes what finally fixed your problem?
  3. QUALITYTRUCK
    1,821
    1,789
    Jun 14, 2009
    romulus,mi
    Post all active codes.
  4. K&G Trucking
    5
    No active codes. It just won’t Regen when I push the button. In November when it wouldn’t Regen is when it went into derate. In December it started doing it again and they jetted the filter again. Just trying to find out what else could be causing this. Because Mac dealer can’t seem to fix the problem.
  5. QUALITYTRUCK
    1,821
    1,789
    Jun 14, 2009
    romulus,mi
    Without monitoring aftertreatment values with laptop during a forced regen it is impossible to give you an intelligent answer. Don't understand why Mack dealer is having such a hard time diagnosing.
    daf105paccar Thanks this.
  6. Truckwork2461
    Truckwork2461 Bobtail Member
    47
    15
    Feb 10, 2021
    No lights coming up on the dash? Other than the filter cleanings what else has been replaced/repaired? Should be able to go 150,000 miles between cleanings. Is the park brake light on the dash when brake is set? All your fluid levels are good? Visually check in case a sensor isn’t reading properly. Have they checked for air in your fuel? Injector sleeves failing can prevent regen too. Won’t always throw a fault code. Have they checked the SCR? So many possibilities. Need more repair history info.
