2015 Peterbilt 579 light issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by HurryUpandWaitTrucking, Feb 6, 2022.
  1. HurryUpandWaitTrucking
    HurryUpandWaitTrucking Bobtail Member
    So 2 days ago I start my day.. turn on my headlights, get a fault code on dash and passenger side low beam is out. Try replacing bulb, but still doesn't work. Check L2 fuse, looks good. As I'm doing pretrip, I also notice rear passenger running light is out.
    I know very little about electrical issues. Any ideas or suggestions would be appreciated.
  3. Arctic_fox
    4,559
    25,967
    Sep 16, 2016
    Easiest fix is to buy a fuse checker or something like this Advance Auto Parts - Down for Maintenance and just check all your fuses in the boxes. If thats not the problem then i would go to a dealer as it could be almost anything.
  4. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,266
    Nov 16, 2012
    SW FLA
    Wait 3 days
    It might fix itself
  5. wichris
    wichris Road Train Member
    4,522
    9,327
    Jan 17, 2011
    Pound on the dash, that cured the old 359's electrical problems.
    GYPSY65 Thanks this.
  6. Bad Monkey
    Bad Monkey Medium Load Member
    576
    367
    Jul 18, 2012
    Goshen, IN
    On mine it was an internal circuitry issue. Got water inside the housing and shorted something and couldn’t fix it. Required a new headlight housing to fix. $500.
  7. MACK E-6
    50,178
    239,922
    That shouldn’t affect a tail light too though...
  8. Bad Monkey
    576
    367
    Jul 18, 2012
    Goshen, IN
    Sorry I didn’t see that.
