My turn signal/ wiper switch is giving me trouble and need to change it. Does anyone know how to tear down the steering column to get to the signal switch? 2015 Peterbilt 579
2015 Peterbilt 579 Steering column tear down
Discussion in 'Peterbilt Forum' started by calvinbabb, Jan 12, 2022.
Remove the plastic clamshells from top and bottom of the column around the turn stalk. You will also need to remove the lower panel to access the wiring and connector. It should all pop apart with plastic trim removal tools.
Ok. I wasn’t sure how the covers were attached and don’t want to break anything to get them off.
'88K100 Thanks this.
