Hello I need some help I a having all of these codes on my truck. Where should I start?
imgur.com
2015 peterbuilt paccar dpf/egr issues. Please help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sam3521, Aug 6, 2022.
You most likely have a wiring issue to your DPF pressure sensor. Start with thorough visual inspection of wiring from the EAS to the sensor for rubs or breaks/ green corroded wires.
LoneRanger, spsauerland and Another Canadian driver Thank this. -
Yes, the little harness to just the delta P sensor rubs wires bad. I keep that short harness in stock in our parts room.
I checked the wiring everything looks good and I unplugged some of the connectors they were very clean on the inside. The short wire loom is clean on all connections and I tested it with multimeter, it works good.
Where is the eas located?
imgur.com
