2015 prostar auto. braking issues
Discussion in 'International Forum' started by Ehpik1, Apr 3, 2022.
  1. Ehpik1
    Ehpik1 Bobtail Member
    Apr 3, 2022
    I have 4 2015 prostars automatic that have trouble braking. When trying to come to a stop the truck seems to keep going forward. Even with the brake pedal pressed the truck keeps leaching forward. I have gone as far as replacing the brakes along with brake valves and this continues. Could this be a transmission issue? Also at times the trash control light will come on. Could that be because of the airbags been over inflated as well?
  3. Hammer166
    7,610
    27,822
    Aug 18, 2007
    ~8600+' and loving it!
    Clutch isn't fully releasing.
  4. Ehpik1
    Apr 3, 2022
    What would be the best course of action? Would it be a transmission issue? Meaning I would need to get the automatic transmission serviced or replaced?
  5. Hammer166
    7,610
    27,822
    Aug 18, 2007
    Could be a linkage issue, actuator might be weak, or it could actually be a loose spring rolling around in the clutch.
    Unlikely to be tranny itself.
  6. Ehpik1
    Apr 3, 2022
    awesome. thanks for the help. going to check all this tomorrow.
    Hammer166 Thanks this.
  7. Heavyd
    Heavyd Road Train Member
    7,829
    6,279
    Feb 4, 2009
    I suspect you have a bad brake switch so the trans doesn't know you are trying to stop to release the clutch. This would explain the clutch and traction control light issue.
