2015 Prostar has stability and handling issues when hooked to a trailer
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Packer1077, May 12, 2020.
  1. Packer1077
    Packer1077 Bobtail Member
    27
    15
    May 12, 2020
    Arizona
    Bought truck in January and have put new shocks, tires, front end suspension, and 3 axle alignment. Now the truck has that unstable feel and when a truck passes it feels like I’m being pushed to the right and hydroplaning feel of poor handling. Feels like truck will roll over when in curves or angled roads. It also feels like brakes are being applied slightly when this happens.
    No dash codes will appear. The only thing that’s on is ABS module in the mileage box area when I start the truck. 9-10 different shops and if there is no code on read out, they just say “there is nothing wrong “. So frustrated with it all.
  3. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,945
    3,315
    Jun 10, 2019
    Sounds like it could be your steering box. You might have loosey goosey steering box issues of a worn out box.
    little cat 500 Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Is the 5th wheel too far back so there isn't enough weight on the steers? 5th wheel have enough grease on it?
    AModelCat, spsauerland and BoxCarKidd Thank this.
  5. Packer1077
    27
    15
    May 12, 2020
    Arizona
    5th centered and the issue was steering angle sensor. Recalibrated it and was doing fine until I was on pitted roads , then went out again. At the 17th International shop since mid March and over $20K later, they agree that sensor is bad. Yaws checked good and can’t find any wires that could be shorting out causing this issue. I have had the sensor calibrated 8 times since May 13th. Will keep you updated on results. To many sensors controlling the truck instead of me.
    Heavyd Thanks this.
  6. Packer1077
    27
    15
    May 12, 2020
    Arizona
    More grease then there would on two 5th wheels. I hate seeing dried up 5th wheels.
    Didn’t put steering angle sensor in as the shop foreman said it has to be Bendix radar on front. They said it was not registered in the ECM? Recalibrated the YAW and angle sensor. Just picked up first load and heading toward home. A little test run.
    When driving in slanted roads (either way)!truck feels in stable as if it going to “roll”. This occurs even on rutted roads I can’t make lane changes it’s a fight against the Terminator. As long as I keep Truck “leveled” it will be okay. It doesn’t matter what speed I’m traveling. HeavyD I have been reading all your post back. I have tried everything at least once. I need to break down and test body controller. Just not sure on testing wires and exactly what I’m looking for Just want to say thank you HeavyD
  7. Heavyd
    7,829
    6,280
    Feb 4, 2009
    Ok, couple of things. To eliminate the abs/stability system to rule it out, remove the abs breakers. Should be two 30 amp breakers for them, usually F8-B and F8-D. This will totally disable your abs/stability system and throw check engine and abs warning lights, but ignore that and try driving it to see if the problem continues. If it does, then you have a mechanical problem with the truck such as suspension or tire problems. If this totally cures your problem, then we know exactly the abs system is causing it. First thing to check is the location of the Yaw sensor at the back of the cab on a cross member to make sure the connector faces rearward, sensor is in the middle of the cross member and the top label does say, "This side up."
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,558
    6,645
    Aug 26, 2014
    Really appreciate your knowledge on things new to me.
    Heavyd Thanks this.
  9. Packer1077
    27
    15
    May 12, 2020
    Arizona
  10. Packer1077
    27
    15
    May 12, 2020
    Arizona
    Ok will do that when I get back to truck in morning.
    Is there a chance that I have a bad sensor or short in wiring? There are no fault codes and only check engine light with no code to go with it. The light goes off. Newest symptom now after “syncing “ Bendix wingman to ECU, now when I’m driving it’s like the engine/truck is trying to decelerate and I’m forced to push harder on pedal. Then it feels like it releases for a short time and does it again. (Cummins isx 15) also, hard to shift transmission like it’s not syncing with clutch/speed. If that makes any sense to you. I’m ready to tackle this issue with your help. Fed up with techs that can’t think outside that darn laptop. I really appreciate your help.
    Heavyd Thanks this.
  11. Heavyd
    7,829
    6,280
    Feb 4, 2009
    Believe it or, another thing I have seen is the front radar unit mounted completely backwards so the radar faces the engine! This doesn't log any codes and can cause the unit to act really weird too. The radar doesn't say "front" or anything on it, so it can happen. The front should be the completely flat side. The label should face rear. On the connector for the radar, the lock part should face forward. Check for this too.
