2015 Volvo D13 engine injectors problem
Discussion in 'Volvo Forum' started by Diesel Power, Apr 28, 2017.
  1. Diesel Power
    Diesel Power Bobtail Member
    45
    16
    Nov 1, 2016
    Hi guys. Is this common that injectors can go bad at such a low millage 282k mi.?
  3. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    S%#t!!!! Some guys are on their third set by that millage.
  4. DUNE-T
    DUNE-T Road Train Member
    7,069
    17,231
    May 10, 2015
    Detroit, MI
    It's usually injector cups, roughly $1000 all together with labor at a dealer
    flood and KB3MMX Thank this.
  5. Diesel Power
    45
    16
    Nov 1, 2016
    My mechanic sad 4 injectors out of 6 are bad. And it has vibration when it idles. It doesn't have now any symptoms of bad cuppers. I just bought this truck and Happy don't know what's been done before. But seems like it's too soon for injectors to go that bad at this millage.
  6. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    282k on mine and had 2 sets of injectors and cups. First set at 147k, second at 270k.
    KB3MMX Thanks this.
  7. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    in what world every dealer you go to will tell you cups and injectors right away i've gotten away with replacing only one sometimes. but i just had one open the other day that had 5 ####ed injectors. this is very normal i will not offer to warranty this job anymore cuz there is no proper way of doing it if you are lucky maybe they can last 5 or 6 years but highly unlikely every year seems more like it to me.
    QUALITYTRUCK Thanks this.
  8. Diesel Power
    45
    16
    Nov 1, 2016
    Thank you guys!
    Nasriza so what's killing those high fuell pressure injectors so fast? Is it fuell quality? Quality of injectors itself? Fuell injection, system design issue?
  9. scythe08
    scythe08 Road Train Member
    2,916
    3,864
    Mar 19, 2007
    Portland, Or
    Wasn't the D13 killed off by Volvo because of all its issues?
  10. Diesel Power
    45
    16
    Nov 1, 2016
    I think it was Volvo D16. They just discontinued this year Volvo D16 in USA not D13.
  11. VolvoTerry
    VolvoTerry Light Load Member
    293
    377
    Sep 7, 2015
    Based out of Omaha,NE
    I feel for you. But sadly I can top this. With 178k miles on my truck I am on my 4th motor. First one spun the rods and bearings due to a build issue. The next two fell victim to cross contamination. This last time the entire motor and from the charge air cooler through and including the clutch was replaced. So far so good.
    KB3MMX Thanks this.
