2015 Volvo D13 engine injectors problem
Discussion in 'Volvo Forum' started by Diesel Power, Apr 28, 2017.
  1. Diesel Power
    Diesel Power Bobtail Member
    45
    16
    Nov 1, 2016
    So sad you went through it. What year is your truck?
  3. VolvoTerry
    VolvoTerry Light Load Member
    293
    377
    Sep 7, 2015
    Based out of Omaha,NE
    It is a 2016. It has worked out well in the end but was a major headache when it was going on to be sure!
    KB3MMX Thanks this.
  4. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    No it's a very good engine. The D16 was killed from low demand.
    The biggest common problem with D13 is the injectors, that's why they changed the design to common rail now
  5. vladcom0
    vladcom0 Bobtail Member
    Have the same problem
    Truck shaking when accelerating but fun part is that it's running great while engine is cold.
    Codes sad that 6th injector is short circuit
    My truck drives only 300 thousand miles
    Wright now at the dealership bay ( they are opening the valve lid an trying to check that injector! Total dissappointment
  6. vladcom0
    Oh yeah almost forget my truck burning def almost like diesel.
  7. Diesel Power
    45
    16
    Nov 1, 2016
    I think this is disappointing! I thought it will make at least to 500k miles. Let me know how it goes.
  8. Diesel Power
    45
    16
    Nov 1, 2016
    By the way. Did you use bio diesel in this truck ??
  9. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    I think it's next to impossible not to get some bio diesel from anywhere nowadays.
    KB3MMX Thanks this.
  10. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Running with bad injectors increases the load on the emissions system, no wonder it was going through a bunch of DEF .....
    Good thing your getting it fixed before the emissions system is destroyed too..
  11. Diesel Power
    45
    16
    Nov 1, 2016
    Agree 100% on that.
