2015 Volvo D13 engine injectors problem
Discussion in 'Volvo Forum' started by Diesel Power, Apr 28, 2017.
  1. jrotra
    jrotra Light Load Member
    85
    23
    May 27, 2010
    Inverness , Florida
    My cups went out at 100000 replaced 3 with injectors under warranty on a 2016. It would be nice to find be something that would help this issue. Since Volvo can't or won't.
    Diesel Power Thanks this.
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Wow they only did 3? Wich dealership was it? That's a dealership that should be avoided. Doesnt take much more to replace the 6pack.
  4. Diesel Power
    Diesel Power Bobtail Member
    45
    16
    Nov 1, 2016
    Yes. It would awesome if we found a solution to prolong injector life at least to 500k miles.
    KB3MMX Thanks this.
  5. jrotra
    85
    23
    May 27, 2010
    Inverness , Florida
    Nextran in Orlando
    Socal Xpress Thanks this.
  6. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    unless someone one to recast the injector housing i have tried and so far no luck with coming up with anything the only thing i can do is that i can usually find the one thats got the issue and replace only that injector and cup had a lot of good luck.
  7. BoostedTeg
    BoostedTeg Road Train Member
    1,884
    3,606
    Jun 2, 2008
    Boise ID
    Are 2017 having the same issues?
  8. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Potentially yes...... just depends on how many miles you get in before the loctite gives out.
  9. nasriza
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    The good thing is that Volvo is updating fuel system in new engine going to common rail it should be 2018 model year they are trying to fix a problem Volvo has had since it first introduced an engin in us they have always had cup issues as far as I can remember. D12 all versions d16 d13 all of them but d13 with stainless cups by far worst than all the other versions
    KB3MMX, Rob100100 and QUALITYTRUCK Thank this.
  10. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    I thought the brass cups were the worst ... Stainless with conical injectors better.
    d281833 Thanks this.
  11. KB3MMX
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    Yes If you can get it down to 4um or less it'll help with life of the injectors.
    There is a 7um Davco filter offered by Donaldson and Fleetguard that are both good.
    We really need a primary filter that filters like a CAT Exceptional Efficiency fuel filter... 3um absolute
