2015 Volvo D13 engine injectors problem
Discussion in 'Volvo Forum' started by Diesel Power, Apr 28, 2017.
  1. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Guys remember the cups support the injector... When it struggles to push that 35,000 psi injection event it creates a ton of resistance when the cam is pushing down on the injector plunger and body.
    Increased deflection of the injector then puts stress directly into the cup.......... The account of support the cup gives is easily exceeded when anything isn't 100% .... Then you have a leak.
    Do yourself a favor and clean the injectors as part of your regular PM and upgrade your prefilter/davco filter if you have one. I run the 7um prefilter and oem Volvo on the motor. I wish i could find something better than Volvo for the motor, it's only 5um ... Wish i could get a 3um to spin on!
    Diesel Power and jrotra Thank this.
  3. jrotra
    jrotra Light Load Member
    85
    23
    May 27, 2010
    Inverness , Florida
    How do you clean your injectors?
  4. Diesel Power
    Diesel Power Bobtail Member
    45
    16
    Nov 1, 2016
    Since you run 7um prefilter. Have you notice any change in performance ?
    Or fuell millage? How often you have to change prefilter?
  5. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Uhh, with Stiction?
  6. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    I dose mine every oil pm at least with injector cleaner concentrate.
    I usually use the Amsoil injector cleaner contrate and mix full strength plus some. Usually a 64oz in each tank. That stuff is crazy Strong ... They originally had a recall because it was eating the bottle lids adhesives it's so strong.. had to change lids..
    . Lol
    The 7um prefilter gets changed about every 10k miles. They're inexpensive to change, i carry a jug for the fuel and a Davco wrench..
    jrotra and Diesel Power Thank this.
  7. Volvo8873
    Volvo8873 Light Load Member
    240
    145
    Apr 27, 2016
    Western Wisconsin
    So the question is what exactly goes wrong when the injector cups go? Does the injector cup deform?
    KB3MMX Thanks this.
  8. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Three ways either cup deforms and lets compression in fuel system as it diesnt seal inj as well. Second cup doesn't seal properly to the head creating pressure in cooling system and third cup has a hole and put fuel in coolant. Three very common with d12 at high miles only first one with d 13 but very often
    KB3MMX and Socal Xpress Thank this.
  9. Jfreezin
    Jfreezin Bobtail Member
    It does not work on D13 or any electronic injectors only oil driven injectors like in a Cat engine.
  10. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    I know that Volvo's running without a DPF still have the same cups problem.
    So the DPF cannot be the cause.
  11. Boromak18
    Boromak18 Light Load Member
    62
    11
    Jan 11, 2018
