2015 Volvo ishift problem , please help
Discussion in 'Volvo Forum' started by northface36, Oct 17, 2018.
i've seen a few of the new ones do the exact same thing that usually happens for fuel efficiency, does it get stuck in neutral or as soon as you hit the gas it engages in gear.
northface36 Thanks this. -
Option for fuel mileage. PS you can shut it off it’s the eco roll setting
Eco Roll. Just pull the Jake brake lever toward you one click for setting to "1" which is 30% braking, 2nd is 70% engine braking then you have a 3rd. (The lever over the windshield wiper lever)
So you have Off, Auto(Eco+Roll), 1,2,3.
"Eco Roll disengages the driveline and lets the truck roll for the optimum period before re-engaging the driveline."northface36 Thanks this. -
There is an adjustable parameter to turn ON or OFF the Eco Roll feature, by default trucks come from factory with this parameter at ON , the PTT tool is require to make the change.
With truck(2013-2014) is was possible to have Eco Roll feature only under cruise control operation not on pedal operation but now you can only turn ON or OFF for both Cruise and pedal.
Ben -
Did you ever get it resolved?
Note : On Volvo truck with I-Shift version F 2018 and Up the Eco-Roll (I-Roll) can be turn ON or OFF using PTT(VolvoTool) transmission parameter and but the option for Eco-Roll on cruise control only, no more exist from factory.
BenNewto Trucking Thanks this.
