2016 Cascadia Trailer Light Gremlins
Discussion in 'Freightliner Forum' started by Mharris90, Jul 12, 2024.
  1. Mharris90
    Mharris90 Bobtail Member
    I have a 2016 freightliner Cascadia. The problem is with the trailer lights, all of them. So when I first start out in the morning and hook up to a new trailer, the lights will be on. However, when I supply the tractor and trailer with air at the hand valves the lights begin to flicker and sometimes will go out. If I take and move the tractor forward, they will also flicker on and off. It is not the electrical cable that runs to the trailer from the tractor, because I have used three different ones and have the same problem. After driving the tractor for about 30 minutes to an hour the problem disappears. It seems like the problem is around some sort of electrical component that is connected to the air system. Any thoughts?
  3. beastr123
    beastr123 Road Train Member
    2,964
    24,337
    Jan 2, 2014
    Moose Jaw SK CAN
  4. beastr123
    2,964
    24,337
    Jan 2, 2014
    Moose Jaw SK CAN
    check your ground connection in the cord. It sounds like the only ground is through the 5th wheel and the grease is interfering.
    Mharris90 and Magoo1968 Thank this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    The socket that the cord plugs into the back of the truck is replaceable. It can get old and corroded in their causing problems like you're experiencing.
