2016 Coronado glider Intermittent No crank
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dberset, Dec 3, 2022.
  1. dberset
    dberset Light Load Member
    75
    35
    Jan 12, 2020
    2016 Coronado glider, intermittent no crank. It might go for days with no trouble. I’ve tested the ignition switch itself to see if it has good contact through the start terminal and it does but no start signal at the mag switch. I’ve been using needle nose pliers to jump the terminals to get it to start. Any help would be appreciated.
    Thanks
  3. xsetra
    xsetra Road Train Member
    5,199
    7,151
    Aug 21, 2011
    I don't know the circuits of your truck. If you have power out of your ignition switch to the mag switch. You have to jump the mag switch terminals to start.
    I think your mag switch is bad.
    Or do you mean you are jumping the terminals on the starter solenoid?
    Did you disconnect the wires and clean them. Corrosion penetrating the terminal ends could be your problem or a broken wire inside the insulating jacket you will not see.
    Good luck.
    Oxbow Thanks this.
  4. Raffito
    Raffito Light Load Member
    84
    53
    Aug 25, 2019
    Ingram, TX
    You may also want to check and clean all the batteries terminals. All ground cables.
  5. Star Rider
    Star Rider Road Train Member
    1,809
    19,324
    Sep 23, 2019
    Change the solenoid on the firewall
  6. dberset
    75
    35
    Jan 12, 2020
  7. dberset
    75
    35
    Jan 12, 2020
    All clean. No start signal getting to firewall relay
  8. dberset
    75
    35
    Jan 12, 2020
    No start signal getting to relay on firewall. I can operate it with my power probe.
  9. dberset
    75
    35
    Jan 12, 2020
    I can use my power probe tho energize the relay via start terminal. There is no power coming from the start wire to make it operate with the key.
  10. xsetra
    5,199
    7,151
    Aug 21, 2011
    run a new start wire from ignition switch.
  11. dberset
    75
    35
    Jan 12, 2020
    If it were that easy I would do that but it runs through the pdm first
