2016 DD13 stop engine, check engine light
Discussion in 'Western Star Forum' started by Leviw, Jun 6, 2023.
  1. Leviw
    Leviw Bobtail Member
    I have a 2016 Western Star with a DD13. When idling, it will throw a stop engine, and a check engine light and then almost immediately shut down.
    I pulled the stored codes and it showed some voltage codes, and a regen code. Did a parked regen on the truck. Cleared all codes.
    Left the truck high idling while the DPF cooled. While at high idle truck threw a stop engine/check engine light and shut down.
    Went to go pull codes immediately after and nothing active or inactive listed at all.
    Has anyone ran into this? Thanks for the help.
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,028
    2,173
    Dec 15, 2021
    I have a 2019 Freightliner with a DD13,company truck.I got 2 check engine lights,they were egr codes.
    I cleaned the egr sensor,just 2 10mm bolts,easy to check.It was full of soot.
    I drove it back to the shop and they cleaned the egr manifold and it runs good now,almost 600,000 miles.
  4. RocketyMan
    RocketyMan Medium Load Member
    554
    337
    Jun 5, 2015
