I have no power to my air controls, bunk heater, all lights but roof light , fridge and all power ports in my sleeper . I checked fuse block and am getting no power to it . Does anyone know what is causing this ????
2016 t660, no power in sleeper
Discussion in 'Kenworth Forum' started by Altransportation, Aug 4, 2019.
60amp fuse under hood mounted to firewall
Where on the firewall I’ve been looking everywhere for it including the firewall tia
It will be a solid blade fuse. You won't see an element. To check it, take it off and shake it. If you hear a rattle it's blown, or use a multimeter to see if power is on both sides.
That black box is just a housing, the fuse is inside it bolted to two terminal studs. -
What about if there’s no mega fuse?
