2016 volvo 780 ishift Problem
Discussion in 'Volvo Forum' started by promero2188, Feb 22, 2020.
  1. promero2188
    promero2188 Bobtail Member
    I have problems with my 2014 volvo 780 550k milles automatic transmission especially on cold days without any alert on the dashboard the red triangle light comes out saying stop. the truck starts to shake and does not want to walk every time I try to accelerate it starts to shake does not put any code or any fault. the engine fails but when put into drive and give gas begins to shake. when I turn off the engine and turn it back on, the light that stops will stop and run again normally this ishift transmission is driving me crazy
  2. Doealex
    Doealex Light Load Member
    272
    432
    Feb 21, 2018
    Call the dealership. Usually I-shift covered for 750K miles
    86scotty Thanks this.
  3. Sharky88
    Sharky88 Medium Load Member
    574
    560
    Sep 25, 2013
    Might not be the transmission. You might want to bring it to a dealer and havE them read the code history
  4. Mysen1
    Mysen1 Bobtail Member
    Jun 27, 2014
    I had a similar problem,my mechanic told me to change Crank case pressure sensor,and that fixed it.
    Sensor was bad.
    Doealex Thanks this.
  • Draft saved Draft deleted
