2016 Volvo problem
Discussion in 'Volvo Forum' started by ercan978, Apr 7, 2023.
  1. ercan978
    ercan978 Bobtail Member
    36
    Jun 29, 2014
    Burnsville , MN
    Hello guys. I got a 2016 Volvo 670 D13 with ishift, 790000 miles on it.
    Truck runs smooth, no fault code, no oil leak, no air leak. But the problem is when I am at a stop sign or lights when I accelerate truck jerks or lurches. After 3 to 5 seconds it goes back to normal. Feels like no fuel going but also feels like accelerate pedal or clutch slipping..And same thing happens when I am rolling very slow in the parking lot or when I back up. Any idea what kind of trouble I am looking at?
    Thank you
  3. Weiboy718
    Weiboy718 Bobtail Member
    47
    34
    Jan 25, 2017
    I had something similar happened to my 2012. My trucks symptoms were similar to yours and it was the EGR differential pressure sensor. No codes as well. You can remove the Venturi pipe and sensor and clean it out. Worth a try!
    KB3MMX Thanks this.
  4. Stringb8n
    Stringb8n Road Train Member
    1,705
    2,236
    Sep 27, 2015
    Try looking in your fuel tank, drivers side and see if you see air bubbles coming into the tank from the fuel return. if you do see air bubbles, it's time for injector cups. If it is time, I would replace injectors as well. Just had to do this to my 2013. I think its foolish to not replace the injectors, especially with mileage in 700's when replacing cups. Labor will be close to the same, if they have to open the valve cover back up to remove and replace injectors in the near future. Another possible culprit, not saying it is just that it could be, is your spigot or pilot bearing in your transmission. I would imagine the bearing, if that was the issue would get worse with time. So will injectors/cups. You still got good power climbing hills and pulling your loads?
