2017 freightliner cascadia headlights issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Atl ahiska, Nov 18, 2024.
  1. Atl ahiska
    Atl ahiska Bobtail Member
    4
    Got 2017 cascadia, had regular halogen headlights, switched to OEM Led assembly headlights now only left side work low beam and high beam, right side low beam doesn’t work but high beam works what can be the issue?
    Didn’t have any issues with previous regular halogen headlight's
    I do get power at harness on right side but when its plugged in the headlight doesn’t come on
  3. OldeSkool
    OldeSkool Road Train Member
    2,228
    7,599
    Jul 17, 2018
    New Hampshire
    Switching to LED sometimes requires more than just plug and play. They make wire in adapters and stuff to make it work right so you don’t have the fast blinker stuff and all. I’m not guaranteeing that you have to have that, but if your old ones worked fine I’d say it’s something like that. Just for the record I had a 17 Cascadia with factory LED headlights and they are awesome. Hope you can figure it out.
    The_vett and Atl ahiska Thank this.
  4. Atl ahiska
    4
    Thanks, i will try to see, maybe its something to do with reprogramming the ecm
  5. 062
    062 Road Train Member
    6,414
    34,286
    Oct 20, 2013
    If the high beam works make sure you don’t have a bent pin or broken wire at the plug.
    It could be a bad light assembly. With the low beams on try tapping on the back and see if it will flicker or anything.
  6. Atl ahiska
    4
    No broken wires, it does have power at cable when i test it with probe, does work with regular halogen bulb as well, the led light assembly is new, and was tested on my other truck and checked out to be working just fine.
