2017 Freightliner coolant leak
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by International2020, May 14, 2024.
  1. International2020
    International2020 Light Load Member
    62
    12
    Dec 17, 2023
    South Carolina
    So I have a 2017 Freightliner Cascadia and I have a coolant leak. I’ve done a coolant pressure test and everything else but mechanics cannot find a leak anywhere. Any ideas on where the hell it’s going I have to put like a gallon in maybe every week and a half two weeks.
  3. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    Check EGR cooler
    If you don't have Detroit motor, find a Cummins video.
    Rideandrepair Thanks this.
  4. International2020
    62
    12
    Dec 17, 2023
    South Carolina
    Hmm ok. There’s probably what it is
  5. Sm0kie
    Sm0kie Bobtail Member
    8
    May 15, 2024
    Pull the mixer pipe (going into intake elbow) and see if it's wet for egr cooler. As previously said. 13mm, 4 bolts, then either a 7mm or 8mm for hose clamp.
    Check oil and make sure it doesn't look like chocolate milk.
    Check fuel and make sure it's not cloudy/separating.
    Check coolant pipes under cab going to bunk heater core. Specifically where the plastic hold down brackets go over them. And make sure bunk heater core isn't leaking.
    Check def tank. Should be clear. (Very rare to have coolant leak into def, usually it's other way around)
    Make sure it's not leaking down onto turbo/exhaust and evaporating.
    biopure22 Thanks this.
