So the company gave me a '17 model international prostar.. Nice only problem is after 5 mins the idle management light comes on and the engines shuts off.. I'm hip to that but usually there is a auto start/stop button. The '17 model doesn't have that. A/C stops blowing cold and it was a very long night here in Texas with no A/C blowing. How do you get A/C all night if there's no auto start/stop button and the engine won't stay on longer than 5 mins ?
2017 Prostar Idle Management
Discussion in 'International Forum' started by Orangemonster25, Apr 29, 2017.
Your company needs to have that changed in the ECM. You might be SOL if thy don't want you to idle it's going to be a long hot summer.
Tb0n3 and Orangemonster25 Thank this. -
The engine is programmed for idle shutdown. Nothing you can do. Unless your truck has the "no idle" HVAC system on it, you'll need to turn that truck in and ask for one you can run all night.
With all the energy and thought that has gone into "idle management", you'd think they would just put on a ###### APU, and be done with the issue... :-/
Justrucking2 and Orangemonster25 Thank this. -
Thanks guys for your responses. The verdict is in.. These 2017 international Prostars have no APU period, no auto start either. What it's supposed to do is between like let's say 40° and 78-95° (company shop has no way of seeing what it's actually set to so I've been given an estimated bracket) there will be no AC period. Once the outside temp reaches above the max setting you are supposed to be able to start the truck up and it should bypass the 5 minute idle management and stay idling so you can run the AC until the outside temp drops below the max setting and they truck will revert back to the 5 minute timer and automatically shut down. Therefore back to no AC within the temperature bracket. Also since there is no auto start for when the battery gets low instead of cranking up to recharge the battery all the power (lights, inverter, built in refrigerator included) shuts off leaving you with no lights or AC. Beware if you're assigned a new truck and you notice there is no auto start and/or no APU !! This is unacceptable and should let your company know that you will not take the truck asap. Afterba long hot weekend my manager is back in the office and looking for me another truck as we speak. Thanks guys!
All because so many jackwagons run the truck all night when it's perfect sleeping weather 45-70 degrees outside and waste fuel and generate noise and fumes for fellow truckers parked nearby.
can't ya just set the trailer brake instead of tractor brake or lay something on the fuel pedal to bump it up
I don't have one but was just thinking of how to keep it running duct tap for the cam will work for sure
They'll pay these guys some unbelievably low rate, and keep one driver on duty for every 20 trucks on the road at the time, and we'll all be bagging groceries we can't afford to buy, or holding cardboard signs up, on the side of a road full of vehicles with no drivers in them.
I'm just hoping that I'm old enough to be dead by then.
