2017 prostar looses power
Discussion in 'International Forum' started by Vaso.L, Oct 15, 2020.
  1. Vaso.L
    Vaso.L Light Load Member
    192
    66
    Jan 2, 2014
    South Holland,IL
    Every 6-10k miles,slows down to 5mph you park it on the shoulder,it shuts off and you cant turn it on next 10 min,after 10min like nothing happened it works normal next 6-10k miles.
    Throws tranny shifter finger code on eld.
    Any idea what it is?
  3. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    Check all battery connections very well.
    Heavyd Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    5 mph is a common derate speed when you have exceeded the allowable time limit when you have any sort of emission fault. The trans shift finger code is usually a broken clutch and it can't disengage to get to neutral, but this will not cause a derate in speed. Being stuck in gear will cause a no start. Seems like sitting is allowing a system reset. Your first step is check it for codes. Like mentioned, checking all battery connections is a good idea too.
