2018 cascadia coax and power wire routeing
Discussion in 'CB Radio Forum' started by craig_sez, Jul 17, 2018.
  1. stacks
    stacks Road Train Member
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    So it definitely isn’t a good idea using that radio of the 12 volt socket
  3. stacks
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    Well I would use wire that isn’t going to loose volts I wasn’t Aware using 10 gauge from the Battery and then connecting it to the factory powerlead would that cause issues .
  4. stacks
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    it’s just a factory power lead standard that came with the radio
  5. Night Stalker10
    Night Stalker10 Road Train Member
    1,707
    1,274
    Jun 26, 2017
    Nebraska
    “As a personal thought,why do we need a fuse on the ground side??”
    It’s insurance against a vehicle fire, or damage to your radio. If your vehicles ground was to lose its integrity, and excessive current tries to back flow through your ground wire, the fuse will blow.
  6. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    NOPE
  7. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Well then your expecting more power to come from factory wire than its ment to..Causes heat and possible fire...Naw just toss the factory all together..
  8. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Here is the vid that made me do my change but there was a vid on youtube of some dude showin a voltage drop using factory harness in a ciggy lighter but cant find that vid..It sparked my interest and got me lookin till I saw the vid of this link..
    stacks Thanks this.
  9. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    USCG standards disallow soldered connections due to vibrations. Then there’s heat & corrosion.
    ANCOR products meet the above and then some. I’ve harnesses on vehicles more than ten years of age similar to new. Started using the brand more than twenty years ago.
    Drawback appears to be initial expense. One is soon over that once Quality is perceived and utilized.
    Marine electronics live a harder life than what’s in our trucks.
    Blue Sea termination fuses if you want to do it “right”.
    My attitude of late is to build power leads that’ll last a great deal longer than the length of time I’ll be in any given tractor.
    And then to feed a West Mountain RigRunner distribution panel. The devices are themselves connected each to a fused Anderson PowerPole termination.
    That, mounted on the back of a TAC COMM radio carrier can be dash mounted. Other devices (speaker, etc) inside or out.
    12 isn’t worth it when 10 isn’t harder.
  10. stacks
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    Interesting video I’ve seen other videos from that guy on you tube the voice is familiar , he has the tools and know how to put together his own power leads,
    And testing Equipment.
  11. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Well when i do it and get my 14.4 volts both my radio an i will be happy...10g will not fit in what i bought...I woulda searched more if i was gonna be needin 20 ft but i dont so 12 will be hugely better than 16g
