2018 Freightliner Cascadia idle control settings
Discussion in 'Freightliner Forum' started by joseph1853, Aug 27, 2018.
  1. joseph1853
    joseph1853 Road Train Member
    1,003
    562
    Dec 12, 2010
    Waco, TX
    All right I'm trying to get this truck to idle throughout the night so that I can have AC. I called Freightliner up they said I have to take it to Ryder and they can set it in the computer. I called Ryder up and they said that I could set it on the computer on the dash. They sent me some settings instructions on how to set it. Said make sure the parking brakes on and Hood latches are latched the doors are closed then go into the optimized idle settings and turn it on which didn't work. Had idle settings but no optimized idle settings that I can find anyways. came across a YouTube video saying you could wait till it goes down into shutdown mode and then push the parking brake in and idle it up and that would bypass it that didn't work either. so anyways anybody got any suggestions on how to get this thing to idle through the night so I don't sweat my butt off.
  3. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    Some will respond to holding cruise set and cruise up at the same time for fast idle.
    joseph1853 Thanks this.
  4. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Well I've taken it to ryder and they hooked up there computer and said the idle shut down is set to off already..They don't know what else to do. Also talked to freight liner again they said it might be password protected and you have to go to a special screen or something that the ryder guy might not have known about..
    10/4 I'll try that next time I'm in the truck. I'm off until Monday.
  5. brsims
    brsims Road Train Member
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    Most times, the idle shutdown is set by outside temperature. If you feel the underside of the driver's side mirror case, you will find a small nub of plastic. That is the outside temperature sensor. Pull the outer edge of your small mirror all the way towards the door, then reach your fingers in to find the plug connection for that sensor. Unplug that sensor (you may need a flathead screwdriver). In a minute or two, your dash will no longer show an outside temp reading. Additionally, the "check engine" and "malfunction indicator" lights will come on. But your truck SHOULD idle from now until you run out of fuel, including idling up for regen if necessary.
    This is on a 2018 Freightliner Cascadia in the older body style.
  6. tinytim
    tinytim Road Train Member
    5,145
    19,357
    Oct 29, 2007
    Northern Ontario
    This may help.
    Issue
    This is a new "feature" on all of the New Cascadia vehicles. It is called "inactive idle shutdown" and is present for fuel economy reasons. The feature will shutdown the engine after 45 minutes of idling even if the idle shutdown is disabled.
    Solution :
    To disable this feature, the CPC parameter : PG360 - Enable inactive shutdown -- needs to be change to "disabled". All of the New Cascadia vehicles will come from the factory with this parameter enabled.
    joseph1853 and QUALITYTRUCK Thank this.
  7. Trucking in Tennessee
    3,740
    5,740
    Mar 19, 2018
    Nashville
    It won't be long before the only controls we have are stop and go. My manual shift is disabled.
  8. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Thats awful.
  9. tallmon
    tallmon Medium Load Member
    657
    321
    Oct 22, 2014
    Some of my 2011s had this"hidden" parameter, too. Drove me nuts until I found it.
  10. #wishfulthinking
    #wishfulthinking Light Load Member
    203
    551
    Jun 9, 2018
    Central Iowa
    I have a 2018 Cascadia too. Same issue, except mine has an APU. I’m so disgusted with the Economy settings on this truck, I’ve asked the company to trade it off with one of our Columbia gliders. #### truck only had 19k on it
  11. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    I figured it was something like that. I stopped at a ryder and a guy hooked a computer up to it and couldn't figure it out. I guess he didn't see the setting you mentioned. I've returned the truck since and got my old truck back. I even tried put a peace of wood on the gas petal to keep it idled up and that didn't even work. it still shut her down after so many minutes. Well if they ever give me that truck model again I'll know what to tell them. Thanks for the info.
    feldsforever Thanks this.
