2018 Intl LT no sleeper air flow
Discussion in 'International Forum' started by SupraJon, May 25, 2020.
  1. SupraJon
    SupraJon Bobtail Member
    4
    May 25, 2020
    Got a 2018 Intl LT.
    Basically AC up front runs great and now suddenly NO AC in the sleeper. Display for temp and fan controls are working but don't do anything. I've checked all fuses and even went so far as to pull all connections and reset blower motor etc on passenger side access panel.
    Still nothing.
    Any thoughts or ideas?
  3. shaggychan
    shaggychan Bobtail Member
    11
    8
    May 24, 2020
    The problem is “International”
  4. Moosetek13
    Moosetek13 Road Train Member
    15,028
    19,106
    Nov 1, 2010
    Burnsville, MN
    If you have a battery cut off switch, use it.
    Cutting power to everything for 5-10 minutes will cause everything to reset. Sometimes that can fix those sudden little glitches.
  5. SupraJon
    4
    May 25, 2020
    I'll try that in the morning.
  6. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    Did you check for power at blower motor?
  7. SupraJon
    4
    May 25, 2020
    Regrettably don't have a volt meter reader on me.
  8. SupraJon
    4
    May 25, 2020
    Final update... #### power and ground wires are #### for their connections.. that's the culprit
    Heavyd Thanks this.
  9. Tb0n3
    Tb0n3 Road Train Member
    4,748
    9,671
    Oct 5, 2012
    Earth
    Figured I'd share what seems to be a recurring issue with the motors on these. Red powder from the stator grinding itself away. It was on the motor as well as piled inside of the squirrel cage top.
