2019 Cascadia front speaker, how to remove?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Metron, Oct 14, 2019.
  1. Metron
    Metron Bobtail Member
    27
    4
    Oct 19, 2011
    USA
    Has anyone popped the grill covering the door speakers on a 2019 Cascadia? I'd like to install aftermarket pieces.
    My radio has the full Sirius xm package, so that stays. I'll be adding a minidsp 2x4 dsp and a powered Klipsch sub to fill in the bottom end.
  2. truckdriver31
    4,963
    5,392
    Sep 18, 2013
    make sure not to thump at the truck stop when you park at night. the person in the truck beside you can hear as they sleep
    D.Tibbitt Thanks this.
  3. Derek driver
    Derek driver Bobtail Member
    Hi Metron ..
    Did you figured out? .
    I have the same issue...checking this forum every few days and is no any response so far...I'm planning to do the same thing because original radio and speakers sounds terrible. So far I ad ( replaced) sleeper speakers and ad subwoofer and I can tell there's HUGE difference in sound quality, but I still need to get....the door which is more challenging... if you have any advice...PLEASE respond...to this post...Derek- driver
  4. Metron
    27
    4
    Oct 19, 2011
    USA
    I did get it figured out. I'd like to shoot a quick video and put it on youtube. Might be easier to explain that way. I'll work on it in the next few days.
  5. Derek driver
  6. Derek driver
    Thanks Metron ...will be GREAT . I tried few times already and without success so far , because definitely I don't want to damage anything...Looking forward...Thanks again.
    Derek-driver
  7. Dabigmack117
    Dabigmack117 Bobtail Member
    Hey where would i find that video im tryin to replace my front speakers without damaging the grills
  8. Metron
    27
    4
    Oct 19, 2011
    USA
    Sorry for the late reply. Been running so much. For now the best I can do is to give some tips, and a couple of pics. Otherwise, I'm on YT as "hifi trucker", got 1 vid with a demo of my old 2018 Freightliner. I have the same Pioneer deck (deh-8800bhs) now in my 2019.
    The speaker grill is plastic welded to the door panel. Remove the plastic welds and you'll be able to pop the grill any time you need.
    - T-30 bit for the various screws, including 4 or so under the door handle cover.
    - door handle cover has 2 slots, insert a flat screwdriver, pry up with force, you won't break it
    - window switch panel, pry up with knife or flat screwdriver, easy disconnect
    - lift door panel up and away
    -take a knife to the plastic welds and remove enough material to push the grill out, the grill will snap back in place so it's all cool
    The speaker is a 5 1/4 inch, depth is 2 inches, horrible sound quality. I already changed the deck to a Pioneer deh-8800bhs. I'm looking at Hertz, Helix or Ground Zero for replacement speakers. I wanted Audio Development but the depth is 2.25 inches, too deep.
    https://photos.app.goo.gl/8RvpaQEg47g5pHt19
    https://photos.app.goo.gl/R2P1VLu7fKHwSZta8
    Edit: I've done more research on aftermarket speaker selection. It might be a bit tricky to select something that just drops right in. I'm thinking it might require a spacer adapter. At my next hometime I plant to take one of the oem front door speakers with me for measuring. I have a feeling I might be able to squeeze a 6 - 6.5 inch speaker in there. Depth will still be an issue.
  9. Grumpyman
    Grumpyman Bobtail Member
    17
    Jan 23, 2011
    Edmonton,ab
    Have u changed out speakers yet? I have 2019 Cascadia and put in kickers 6.5 and had to make a few new holes but work great.. now I just have to figure what to do to make the info center get rid of message saying speaker problem get serviced soon.. there are two pairs of speaker wires going to original speaker for I'm guessing lane assist, need to know how to get rid of message. I might try a cheap speaker on the other wires to see if it cancels out. Heres pics of original speaker. Hope this helps someone out.
  • Draft saved Draft deleted
