2019 cascadia Regen issues. Fluctuating idle
Discussion in 'Freightliner Forum' started by tmmike80, Nov 2, 2024.
  1. tmmike80
    tmmike80 Bobtail Member
    Having a strange issue when I try to do a required regen. Sometimes the idle will jumble over the place and the temperature won't get hot enough and the regen won't complete. If I shut down for 20 minutes to an hour it'll sometimes work, sometimes it won't. Any ideas??
  3. xsetra
    xsetra Road Train Member
    5,195
    7,145
    Aug 21, 2011
    Clean the (7th) injector in the exhaust pipe after the turbo. Some soot can build up and not allow the diesel to spray and mix in the exhaust.
    I had to do that on my 2017-DD15. I tried to regen for couple hours, exhaust wouldn't get hot enough.
    Called Freightliner mechanic. He had me clean the port and it only took 45 minutes for regen.
