2019 Freightliner - Fuel/DEF issue
Discussion in 'Freightliner Forum' started by AMPTrans, Feb 11, 2022.
  1. AMPTrans
    AMPTrans Bobtail Member
    240 miles after fueling and filling the DEF tank, the truck fuel and DEF guages went to zero and the truck shut down like it was out of gas. However, after examining, there was plenty of fuel and DEF. What would cause this problem? It's dangerous to be coast to the side of the freeway... Ryder (who owns the truck) says they cannot find a problem. ???
  3. FLHT
    FLHT Road Train Member
    1,441
    2,588
    Aug 2, 2014
    Tank Vents ?
    Fuel line collapse ?
  4. msh
    msh Light Load Member
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    call to towing company.
    AModelCat Thanks this.
  5. AModelCat
    165,192
    Their truck, their problem.
    Sounds like an electrical issue to me.
    msh Thanks this.
  6. msh
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    yes. i would check datalinks first
  7. Andreybanyuk
    Andreybanyuk Bobtail Member
    34
    24
    Feb 26, 2017
    Possible electric short on the main harness. Mine had this issue and the dealership fixed it free under warranty.
  8. Antinomian
    Antinomian Road Train Member
    2,187
    3,482
    Feb 17, 2013
    2019 is a bit early for the power distribution module to be going bad. But everything shuts down like that when they do. You usually get a few episodes of everything shutting off, then coming right back on before it fails altogether.
  9. msh
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    they lied... there is no suck a thing like main harness. Also def gauge is not hardwired to def tank sensor...
