2019 volvo 760
Discussion in 'Volvo Forum' started by salim patel, Apr 1, 2023.
  1. salim patel
    salim patel Bobtail Member
    40
    6
    Nov 15, 2015
    Whenever I m driving through rain snow or hit pothole hard I get abs. tcs .slippery road sign . And cruise control stops working. And when I stop restart engin things gose to normal . Any insight would be appreciated. Thanks.
  3. salim patel
    40
    6
    Nov 15, 2015
    No one has this type of problem on there volvo truck?
  4. disoba
    disoba Light Load Member
    53
    59
    May 7, 2013
    Because when you hit a pothole the tire bounce up in the air for a fraction of a second but is enough for the sensor to detect a slip,
    rain or snow is obviously slippery so, no worries it's how suppose to work..
  5. DUNE-T
    DUNE-T Road Train Member
    7,078
    17,256
    May 10, 2015
    Detroit, MI
    On the older Volvo I would say ecm harness itself or connections to batteries, on the new ones I am not sure hows everything connected
    Siinman Thanks this.
  6. salim patel
    40
    6
    Nov 15, 2015
    Thanks very much I appreciate the response. I know somwere loos wire in harnesses probably abs . But I thought maybe someone else had identical issue and if they repaired it I can go straight to the location. And not have to look everywhere.
  7. DUNE-T
    7,078
    17,256
    May 10, 2015
    Detroit, MI
    Try tightening battery wires first
  8. jdchet
    jdchet Medium Load Member
    542
    771
    Sep 3, 2012
    NE Ohio
    Got in a new VNL this past August and the battery cables were loose. So were some of the hose clamps on the coolant hoses. Must be some limp wristed MF'ers in Virginia these days! LOL!!!!!!
    JD
    Siinman and ducnut Thank this.
  9. ducnut
    ducnut Road Train Member
    2,683
    8,138
    Dec 31, 2010
    SPI
    You shouldn’t be needing to shut off the engine and restart. Once the system detects things returned to normal, it should automatically reset and allow full functioning of everything.
    salim patel and Siinman Thank this.
  10. Siinman
    Siinman Road Train Member
    5,568
    14,303
    Mar 5, 2017
    Kansas City, MO.
    Like others said most likely wiring issue or battery wiring not tight. Any codes?
    ducnut and salim patel Thank this.
