2020 Anthem Rear suspension air pressure gauge.
Discussion in 'Mack Forum' started by Elroythekid, Apr 10, 2026.
  1. Elroythekid
    Elroythekid Road Train Member
    2,626
    5,678
    Sep 9, 2010
    Halifax Nova Scotia
    I have a 2020 Anthem i recently purchased. It didn't have the air pressure gauge for the axels in the menu. I was "told" by the dealer i bought it from (i didnt notice it didnt have it when i picked it up)it has the sensor on the right rear airbag and that it just needs to be turned on in the menu.
    I took it to my local dealer, who first daid no, it doesn't work like that. But then they had it for another reason (DEF LEVEL SENSOR) they put a new sensor on the rear airbag, turned it on in the dash, but it won't read it. The tech wrote that he installed and accessory kit? And he can see the pressure in the bendix program but it won't show up on the dash. They charged me $400 for that, darlings that they are.... so, does anybody have any ideas? Have a friend with the samebyr truck and he has another sensor on his front left airbag that I dont have and his gauge works?
    Thanks!
  3. 062
    062 Road Train Member
    6,435
    34,412
    Oct 20, 2013
    @nasriza may be able to help it’s kinda a Volvo.
    Elroythekid Thanks this.
  4. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    this sensor is mainly for your ABS/TCS system to tell it trailer weight or truck weight also works for trans to be able to know load so it can change shifting patterns, easy to add another gauge but they will not be able to figure out the programming to make that gauge work on your infor display there is a lot of options out there for wireless sensors that can even connect to your phone to tell you weight on vehicle cheaper option or running a mechanical option.
    062 Thanks this.
  5. Elroythekid
    2,626
    5,678
    Sep 9, 2010
    Halifax Nova Scotia
    My friends has a second pressure sensor on the front axel, left bag that I dont have, wondering if that one is for the gauge. They turned the gauge on, so I can see it now, but its not getting any readings from the sensor, even to in the bending program you can see the pressure. It looks like the connector is there for the front airbag, if I add a sensor there will it read?
