2020 Freightliner Cascadia ATS Electrical system problem detected
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Burlylovehammer, Mar 5, 2021.
  1. Burlylovehammer
    Burlylovehammer Bobtail Member
    I just got a PM done on my 2020 Cascadia and after driving about 100 miles the check engine light came on. When I checked the diagnosis it’s giving me a ACM code 3223 and 520363 ATS electrical system problem detected. What could be causing it and is it safe to drive to my next location until I get it fixed?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,576
    6,669
    Aug 26, 2014
    Google those and use the search block at the top right.
    Then ask again if needed.
    QUALITYTRUCK Thanks this.
  4. Andreybanyuk
    Andreybanyuk Bobtail Member
    34
    24
    Feb 26, 2017
    Bad NOX sensor. Had this code, you will get more codes soon.
  5. Highway_bully
    Highway_bully Bobtail Member
    7
    May 6, 2021
    Having same issue. Is it an easy fix?
