2020 Great Dane Trailer ABS light, TA won’t fix
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Anonymousproxy, Aug 30, 2021.
  1. Ross_Tech
    Ross_Tech Light Load Member
    Aug 31, 2021
    133
    Thanks Received:
    134
    I've seen where the sensor configuration was wrong, and the ecu will say the fault is with "YE1" but it's actually the other side. Also, I'm not positive, but if your 7 wire is worn or loose, and the ABS ecu loses power while the wheels are turning, it may log a fault.
  2. mtoo
    mtoo Road Train Member
    Jan 15, 2011
    1,936
    Thanks Received:
    4,513
    Retired on bended knee
    I had no idea that truck stop shops were considered a real repair facility.
    p608, D.Tibbitt, DrFlush and 2 others Thank this.
  3. OldeSkool
    OldeSkool Road Train Member
    Jul 17, 2018
    1,882
    Thanks Received:
    5,811
    New Hampshire
    I always thought maybe let them patch a tire and that’s about as much as I’d let them do. I think I’d pay a wrecker to take me to a reputable shop before I’d use them if it came to that.
    JoeyJunk and mtoo Thank this.
  4. TheIncredibleBulk
    TheIncredibleBulk Light Load Member
    Nov 6, 2020
    88
    Thanks Received:
    112
    MS/LA
    Used some of that WD40 fast drying contact cleaner on the last two trailers that I had ABS issues with and it worked.
  5. Anonymousproxy
    Anonymousproxy Road Train Member
    Mar 2, 2015
    2,131
    Thanks Received:
    4,433
    Currently running an older trailer, only this time the problem is even worse. I’ve already had it fixed 5 times and still popping the #### on. Now again stuck at a TA shop(company refuses to get me into a trailer shop) 10 + hours to get it fixed again.
  6. D.Tibbitt
    22,243
    Thanks Received:
    153,015
    Unbolt the trailer socket from the trailer and check the back of the plug where the wires screw in, for corrosion. The abs will be the blue wire in the middle.
    Check both the truck and trailer socket. I uses to have the same problem everytime id hit a bump it would flicker. Wires were corroded on the back of the truck plug. All you need to re wire the socket is a phillips head screwdriver, wire strippers and a new plug. And a 10mm socket for the bolts holding it to the trailer.. The plug and cord is always the easiest and cheapest place to start and solves most electrical problems concerning the trailer.
    loudtom Thanks this.
  7. D.Tibbitt
    22,243
    Thanks Received:
    153,015
    If its happening on multiple trailers. Then the problem is with your truck . most likely going to be your truck electrical plug and socket
    JoeyJunk, jsnell and sebas9558 Thank this.
  8. jason6541
    jason6541 Road Train Member
    Mar 5, 2012
    2,425
    Thanks Received:
    5,366
    Omaha, NE
    Get one of these and some brake clean and clean male and female ends. Apply dielectric grease and try spreading your pins ever so gently to make better contact. Or stuff and old seal between plug and receptacle on trailer to take up slack and provide better connection.
    dought it’s the trailer. 7 way cord bouncing and breaking connection
    JoeyJunk and D.Tibbitt Thank this.
  9. BigGreenKDub
    BigGreenKDub Bobtail Member
    Mar 19, 2024
    Thanks Received:
    Vineland NJ
    Just unplug it somewhere along the line get loom and wrap the #### out of the line with zip ties and looming, DOT will not rip all that #### off...ABS on trailer is something you can fix 5 million times and it breaks 6 million it's an absolute pain in the ###.
    Rubber duck kw and OldeSkool Thank this.
