2020 Kenworth MX13 adding a Bypass filter
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ColumbiaBoB, Dec 29, 2024.
  1. ColumbiaBoB
    ColumbiaBoB Light Load Member
    191
    21
    May 3, 2011
    Des Moines, IA
    Hi, i have 2020 kenworth with mx13 in it, looking to put bypass filter but can't figure out where to get oil from. Does anyone know where could i get oil feed from. TY
  3. Ridgeline
    22,768
    124,432
    I think you have that already, it is the metal domed filter you change out.
    krupa530 Thanks this.
  4. ColumbiaBoB
    191
    21
    May 3, 2011
    Des Moines, IA
    It is, but i want to install aftermarket.
  5. Ok big boy
    Ok big boy Light Load Member
    101
    113
    Jan 22, 2014
    Normally the filter maker has a kit and can give you the location of the inlet and outlet ports to use. Which bypass system are you looking at?
    Deezl Smoke Thanks this.
  6. Banker
    Banker Road Train Member
    4,607
    15,420
    Aug 19, 2012
    I have an OPS and it uses one of the side plugs on the oil pan. Everything you need comes in the installation kit.
    Ok big boy Thanks this.
  7. ColumbiaBoB
    191
    21
    May 3, 2011
    Des Moines, IA
    AMSOil
  8. Ok big boy
    101
    113
    Jan 22, 2014
    I looked up the Amsoil filter.I see what your saying.Someone should know.
