2020 Volvo 860 front Heavy
Discussion in 'Volvo Forum' started by Jrb71888, Jul 25, 2020.
  1. Jrb71888
    Jrb71888 Bobtail Member
    Sep 27, 2018
    So me and my wife have a Volvo 860 and it seems like its ridiculously front heavy I'll run the tandems full forward and still be around 11800 on the front axle and I don't know if it's something with this particular truck or if Its a typical Volvo problem?
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Where is your fifth wheel set at?
    AModelCat Thanks this.
  4. Lysdexis
    Lysdexis Road Train Member
    4,483
    47,940
    Oct 25, 2018
    So if you're 80k and legal on all your axles what's the problem?
  5. keebler13579
    keebler13579 Road Train Member
    1,000
    2,007
    Nov 16, 2012
    I have a volvo and that is normal with fifth wheel mid way. Mines not an 860. Woth 5th wheel all the way forward i have seen steer axle weights around 12500
  6. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    Volvo problem, 780s are close to limit on steer, even bobtail.
  7. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    volvo steers have always been heavy. Mine run around 12400 loaded with the 5th wheel set in the middle, never been bothered by dot. I would not worry about it as long as you are at legal weights
    KB3MMX Thanks this.
  8. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    What axle do you have?
    Should be at least a 12,500# most 860s are 13,200# axles , you're nowhere near that.
    I run 13,300-13,600# regularly
    You do know that 12k is not the legal limit for a steer unless your truck axle and tires are only rated at 12k ...
