2022 Peterbilt 567 - Front Axel axle
Discussion in 'Peterbilt Forum' started by bonder45, Jul 27, 2021.
  1. bonder45
    bonder45 Road Train Member
    1,773
    5,302
    Oct 2, 2011
    Williston, ND
    Peterbilt gurus…. I’m in the process of getting a couple heavy haul trucks built.
    They are going to be full heavy spec trucks, 46k rears, 20k front, double frame, 20k pusher, 604 X15……. My question is should I get a set forward or setback from axle….
    This truck will be used for NGL hauling on 50%/50% highways dirt roads, water work in the oilfield and eventually heavy haul on the highway.
    ( I know a lot of paths but diversity is what I do )
    Help?
  3. Nss
    Nss Light Load Member
    73
    34
    Jul 5, 2021
    What is pin setting on the trailers you pull? You think you will get 20k on steer axle?
  4. bonder45
    1,773
    5,302
    Oct 2, 2011
    Williston, ND
    I have 8 different trailers with pins from the front to 8 feet back from the front.
  5. Roberts450
    Roberts450 Road Train Member
    2,237
    3,634
    Feb 6, 2016
    Set back axle would probably be easier to get a full 20k on not to mention shorter wheelbase and easier maneuvering around skinny roads and tight job sites. @TripleSix might have some more insights as well. The spread on the drives and pusher gonna be the standard 9’ or is it gonna be wider? What wheelbase you looking at and any sleeper?
  6. bonder45
    1,773
    5,302
    Oct 2, 2011
    Williston, ND
    54” rear axel spacing / same for pusher
    80” sleeper
    Roughly 280” wheelbase
