2023 Freightliner Issue - PLEASE HELP
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Beupsoon96, Jun 16, 2023.
  1. Beupsoon96
    Beupsoon96 Bobtail Member
    22
    21
    Nov 15, 2020
    2023 Freightliner Cascadia experiencing 13 to 13.6 volts constantly fluctuating at idle and drains to 9 volts instantly when engine is off. Parked for my 34 hour reset Thursday evening and began smelling Sulphur, hopped out and a battery was boiling with smoke spewing out. Took to shop this morning and literally just had batteries checked and one replaced a few hours ago at Love's. Problem isn't fixed...... Thinking alternator because I've been smelling a hot/burning smell after a long day of driving and it wasn't tested today when batteries were. What's weird though, the voltage goes up fine when started, so the alternator must be working right? It just instantly begins dying when turned off. What do y'all think? I'm a lease op so I desperately need help here. Just bought the new battery, was in a freightliner shop twice last week, and I'm getting a new trailer tire in the morning after a puncture. I'm not made of money and dispatch offers crap rates......
  3. Animosus
    Animosus Heavy Load Member
    734
    2,916
    Dec 7, 2015
    SE Wyoming
    Probably need to replace all four batteries. Get them all tested.
    Rideandrepair and Beupsoon96 Thank this.
  4. Beupsoon96
    22
    21
    Nov 15, 2020
    They were all tested today, one was replaced. I assume that was the one that'd been boiling. No Sulphur smell now, but the voltage problem is still here and now worse. It's honestly scaring me. Don't know whether to keep digging the financial hole I'm in or walk away now.
    Rideandrepair Thanks this.
  5. northstarfire0693
    northstarfire0693 Heavy Load Member
    865
    598
    Jul 1, 2006
    NC
    You have something grounding out and draining the batteries. If the voltage shows normal with the truck running, then I dont see an issue with the alternator. Check the wires from the battery to the truck. Look good. you may have one chafed out contacting the frame. This is something that could burn the truck down,
    Siinman, Rideandrepair and Beupsoon96 Thank this.
  6. Rideandrepair
    17,578
    56,942
    Aug 8, 2015
    2023? No Dealership support? Do you have an inverter? If so, Id disconnect it at the battery. See if that’s the problem.
    Siinman and Beupsoon96 Thank this.
  7. Rideandrepair
    17,578
    56,942
    Aug 8, 2015
    Could be the starter. Could be anything. I guess you could find out by disconnecting it, and see if the gauge goes up, test the alternator the same way. Otherwise you probably need a shop diagnosis. Sounds like you just still have at least one bad battery in the bunch. 2023 is new. Doesn’t make sense.
  8. Beupsoon96
    22
    21
    Nov 15, 2020
    Negative, no inverter. Bare bones truck, no apu, inverter, fridge, pr anything. All I have plugged in is a charger for a cigarette lighter plug to charge tablet and phones.
    Truck has 60k miles and was doing great all week. Barely broken in I'd think.
  9. northstarfire0693
    865
    598
    Jul 1, 2006
    NC
    You have something going on. When the truck is off and you see that much of a voltage drop. Something is pulling mass amounts of power. You most likely have a short in the system. Again, check the wires running from the batteries to the truck.
  10. Beupsoon96
    22
    21
    Nov 15, 2020
    Gonna check first thing in the morning and report back to you guys. Hopefully it's nothing too bad or in a ridiculous spot to get to.
  11. JB7
    JB7 Road Train Member
    1,047
    1,854
    Dec 13, 2022
    Laurel, MD
    Could be a lot of things but you need to have the alternator tested. Bad diodes can cause the drain you are experiencing. A quick and easy test to rule out the alternator.
