2023 prostar door panel removal
Discussion in 'International Forum' started by Crathen, Sep 27, 2022.
  1. Crathen
    Crathen Bobtail Member
    I'm changing the speakers as the stock ones can't handle the deck. Good for audio books but not music. Having issues getting the door panels off. Removed all visible bolts. The panel has standoffs where the bolts thread in, tried pulling but panel doesn't move too far. Don't want to break anything. TIA
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,279
    Feb 4, 2009
    Procedure
    1. Use plastic pry tool, remove door handle cover.
    2. Remove door switch pod from door panel.
    3. Disconnect three connectors from door switch pod in door panel.
    4. Use plastic pry tool, remove door light from bottom of door panel.
    5. Disconnect door light connector at bottom of door panel.
    6. Remove six screws connecting door panel to door.
    7. Use plastic pry tool go between door and door panel to remove six pop fasteners connecting door panel to
    door.
    8. Move panel away from door to gain access to back of door panel.
    9. Disconnect door opener cable from door opener handle on door panel.
    10. Lift door panel to clear door lock and remove door panel.
    Crathen, D.Tibbitt and Flint1 Thank this.
