2050lbs of torque
Discussion in 'Ask An Owner Operator' started by Blkcowboy, Oct 22, 2018.
  1. Blkcowboy
    Blkcowboy Light Load Member
    282
    85
    Apr 11, 2018
    Looking at a x15 performance engine and was wondering if this amount of torque is really nessersary . My main concern being fuel mileage
  3. Peterbiltt
    Peterbiltt Light Load Member
    236
    88
    Aug 21, 2014
    Ontario Canada
  4. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    That's right
    LGarrison, Crude Truckin', SAR and 3 others Thank this.
  5. sirjeff
    sirjeff Medium Load Member
    The more the better, drive it right and you wont burn any more fuel.
    mitmaks, colorado18spd and Blkcowboy Thank this.
  6. Long FLD
    Long FLD Road Train Member
    12,988
    54,504
    Mar 4, 2015
    Torque is what gets you up the hills.
    mitmaks Thanks this.
  7. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    I won't tell you what is going to happen, but I will tell you the differences I've noticed in a 450hp ISX and 550hp D16. I can drive the bigger engine "right", and get 7 mpg with a fair amount of bobtailing mixed in. I can drive the smaller engine full throttle up the hills and jake brake all the way down them, and I get 8 mpg while almost always loaded.
    There's a reason they make smaller engines.
    tommymonza and KB3MMX Thank this.
  8. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    "Main concern being fuel mileage"
    Then no, you need the X15e with 1850Tq@1000rpm
    Performance series is much lower compression and programmed for performance not efficiency.
    With the efficiency series motor you'll want different rears too, in the 2.80 - 3.08 range.
    Big difference in fuel economy, minimal difference in Tq and available at much lower rpm
    20 Mule Team, NoBigHurry and Blkcowboy Thank this.
  9. arrogant steve
    arrogant steve Medium Load Member
    444
    463
    Mar 31, 2016
    East Texas
    8 miles per gallon in an ISX? Doubtful. Aside from the X15 Performance model, all the new engines will get good fuel mileage. Of course it depends on gearing, load, route and driver. I fully believe the driver is the biggest factor.
    I've heard really good numbers on all these engines and believe I could get good numbers with all of them pulling reefer at 75k plus gross weight.
    The drivers saying torque is great are correct. That torque will get you to the top of the hill faster than the rest of us. Your fuel mileage will suffer of course. If that's how you validate yourself, then I would say go for those big hp and torque #'s.
    Lepton1 and KB3MMX Thank this.
  10. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    The more horse and torque, the more fun it is to drive, at least that's my theory anyway.
  11. arrogant steve
    444
    463
    Mar 31, 2016
    East Texas
    I fully agree! I had chance to drive a turned up ISX 15, that truck was fun to drive.
    Orange713 and KB3MMX Thank this.
  12. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    My cats only 550 1850 and getting weaker it seems, needs to be cranked up to 650 or a little better.
