20lbs over on drives
Discussion in 'Experienced Truckers' Advice' started by thatguyfrombk, Aug 20, 2024.
  1. thatguyfrombk
    thatguyfrombk Light Load Member
    52
    34
    Oct 17, 2020
    I’m currently loaded at 79679. 32880 trailer 34020 drives 12460 steers. I’m fully fueled and have an apu. Think if I burned some diesel off I should be ok? Also is the apu exception for the drives or gross? Thanks for the help
  3. mitrucker
    mitrucker Road Train Member
    5,487
    10,315
    Dec 15, 2010
    Lapeer, MI
    It’s for gross. I would still run like that. If you’re really paranoid you could move your trailer axles forward one hole, or if you really want a challenge, move your fifth wheel one hole forward.
  4. bad-luck
    bad-luck Road Train Member
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    20lbs, Don't sweat it you will be fine. You can always say you were legal when you left the shipper, you just ate a big lunch.
  5. thatguyfrombk
    52
    34
    Oct 17, 2020
    My tandoms are slide as far forwards as they can go. My main paranoia is the weigh station on 80 going through NJ. I’m safe up until there
  6. thatguyfrombk
    52
    34
    Oct 17, 2020
    Think if I throw my 80lb dumbbells in the trailer that will fix it?
  7. tscottme
    tscottme Road Train Member
    20 pounds is about 3-4 gallons of fuel. I'd run with it.
  8. bad-luck
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    Oh jeez.... then he will be over 100lbs...
  9. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    In 20 miles you will have burned off 20 pounds.
    And where did you find a scale that measured down to the pound?
    79679????
  10. thatguyfrombk
    52
    34
    Oct 17, 2020
    even if I throw em in the back by the doors?
  11. thatguyfrombk
    52
    34
    Oct 17, 2020
    Sorry brotha. That was me rounding the number I’m at 79670
