21 Cascadia turning vane
Discussion in 'Freightliner Forum' started by Zapri, Mar 19, 2023.
  1. Zapri
    Zapri Bobtail Member
    4
    Aug 18, 2018
    Does anybody know how to take that thing off of the door?
    I'm suspecting it causing the wind squeal I keep hearing. I've adjusted the door, it's much better but it's still there.
    What's it supposed to be doing there anyway?
  3. AlexR_uz
    AlexR_uz Bobtail Member
    19
    14
    Sep 10, 2019
    PA
    I guess you can take it out and cover holes from nuts with some plastic clips. Check inner side of the door frame.
    Guys at dealership told me those stabilizers are for aerodynamics and reducing wind noise.
    Check all rubber stripes around door frame and window. Maybe one of them is loose and making this sound. Also check the rubber around windshield.
  4. Zapri
    4
    Aug 18, 2018
    That's the problem, how do I take it off? No visible fasteners, seems as it is on some sort of clips maybe, don't know.
  5. AlexR_uz
    19
    14
    Sep 10, 2019
    PA
    Easiest way is to go to any Freightliner’s parts department and ask them to show you diagram for that area. They will tell you what is holding it.
    tscottme Thanks this.
  6. Dave_in_AZ
    428,146
  7. TNSquire
    TNSquire Medium Load Member
    571
    1,967
    Oct 13, 2016
    Decatur, TN
    My Cascadia whistles in high winds.. The mirror arms are the cause.
    Had the window open, on the interstate, into the wind... Tested the theory, put my hand to block airflow on various places...
    It was the joint between the vertical mirror section and the horizontal arm section...
    No idea how or why, but that's what I discovered
    Zapri, JoeyJunk and bzinger Thank this.
  8. Zapri
    4
    Aug 18, 2018
    Well crap, got whole bunch of ice on the mirror today and behold: no squealing.
    Now to figure out what do... Tape the gaps up..?
    [​IMG][/url]
    TNSquire Thanks this.
  9. Cattleman84
    Cattleman84 Road Train Member
    10,054
    71,928
    Nov 1, 2017
    The Sticks, Idaho
    Take the whole dam assembly off and go to the old school west coast mirrors... Besides they look better anyway.
  10. TNSquire
    571
    1,967
    Oct 13, 2016
    Decatur, TN
    Tape never lasts...
    Cram a piece of card stock in the gap.
    It'll get wet and swell, then a sharpie to make it blend in.
    Is pretty tacky, but it works, and it's free
    Zapri Thanks this.
  11. Numb
    Numb Crusty Curmudgeon
    4,347
    10,332
    Jan 30, 2012
    Charlotte, N.Carolina
    what is a "turning vane" ??
    hope not dumb twucker Thanks this.
