22.5s on open decks?
Discussion in 'Flatbed Trucking Forum' started by RollinThunderVet, Sep 25, 2019.
  1. RollinThunderVet
    RollinThunderVet Heavy Load Member
    717
    970
    so recently i had an issue where my tires were the limiting factor on a run. since then i have been looking at RGNs and Double drops, and it seems most of the 22.5s are ran with 255/70s on them. however im finding none that are rated higher than my Goodyear Endurance RSAs are at 5070lbs in dual configuration.
    i have to be missing somiething here, cause i see RGNs pulling massive freight that appears well beyond 40k(tire rating) on a tandem..
    Lepton1 Thanks this.
  3. Rontonio
    Rontonio Road Train Member
    6,491
    47,934
    Aug 9, 2009
    This is because you need to run 16 ply tires
    9B875BA4-6E6D-4EF1-B096-B90608D19D07.png 869F14B7-DB5E-4091-9384-AAA9359A8DAF.png
    cke and Cat sdp Thank this.
  4. Rontonio
    6,491
    47,934
    Aug 9, 2009
    I know what he was looking at. He was just mistaken about the tire size guys are typically running on RGNs.
    And if you are telling me what I should pull to make a a living - maybe you should worry about you. I a have reasonably good handle on equipment requirements in my segment
    cke, stwik and Tug Toy Thank this.
  5. Aamcotrans
    Aamcotrans Road Train Member
    1,044
    1,803
    May 24, 2016
    Strasburg, Va
    Wow, a guy gives you a piece of honest advice due to his experience and you act like a Richard...
    You must be the life of the party..
    shogun, D.Tibbitt and Fire ant Thank this.
  6. Rontonio
    6,491
    47,934
    Aug 9, 2009
    He “offered” me a piece of unsolicited advise that is totally irrelevant assuming I pull certain equipment and don’t understand the complexities of tire rating and rates for RGN
    I offered the OP the answer to the question he was asking....
    And lastly - who are you the party police ?
    cke and Tug Toy Thank this.
  7. Razororange
    Razororange Road Train Member
    2,720
    25,864
    Dec 20, 2011
    Milwaukee, WI
    One of 3 possible answers here:
    1. They might look like 255/70R22.5 from a distance but are actually 275/70R22.5 and have a load rating of 6395 each.
    2. The machine might look big but weigh less than you think. Thus they are legal weight.
    3. They are running above the load rating of their tires because they aren't smart enough to buy the right tires.
    You can easily run 275 instead of 255. The tire will be about 3/4" wider and 1/2" larger diameter. If you do decide to upgrade make sure the wheels, axles, and suspension are rated to match the heavier rated tires.
    cke Thanks this.
  8. RollinThunderVet
    717
    970
    @Rontonio he was talking to me about not moving to an RGN at the moment.
    The RGNs I'm referring to are in fact 255/70
    I'm quite aware 275/70 goes up to J rating, but I have a brand new set of 255s so I cant justify another set.
    @Razororange I'm going off ones I have laid eyes on personally and those listed for sale. I agree with people overloading. I'm sure most troopers/DOT arent checking, but I'm too scared of getting put OOS to risk it.
    I've seen tandem axle landolls with 50k dozers on 17.5s. Crazy.
    Fire ant Thanks this.
