22k suicide coil. How many chains?
Discussion in 'Flatbed Trucking Forum' started by Rideandrepair, Oct 21, 2024.
  1. Rideandrepair
    17,563
    56,901
    Aug 8, 2015
  3. Espressolane
    18,687
    117,133
    3 minimum, 4 will do the job very well.
  4. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,957
    Oct 31, 2023
    Depends on chain and binder size.
  5. Rideandrepair
    17,563
    56,901
    Aug 8, 2015
    3/8” I used 4 just in case. Another Flatbedder said I only need 2. That can’t be right.
    cke, singlescrewshaker and austinmike Thank this.
  6. Razororange
    Razororange Road Train Member
    2,720
    25,864
    Dec 20, 2011
    Milwaukee, WI
    2 is technically legal up to 26,400 with 3/8 G70 chain. More is better with a coil though.
    Personally I would do 3. 1 straight through or very slightly back depending on tiedown points and 2 more pulling forward and back connecting right in line with the 4x4s under it.
  7. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    No, no flatbedder would ever say anything besides "it looks ok, but me, I'd throw another chain on" no matter how many chains were already on it!
  8. jamespmack
    216,553
  9. bryan21384
    bryan21384 Road Train Member
    15,741
    34,301
    Sep 18, 2009
    Memphis, TN
    If your chains are rated 5000 lbs, 4 satisfies DOT requirements, 5 gives you peace of mind. Me personally, I would put 5.
    Rideandrepair Thanks this.
  10. Razororange
    2,720
    25,864
    Dec 20, 2011
    Milwaukee, WI
    Well none of that is correct.
    3/8 G70 is 6600lbs WLL per chain which he said he was using above. Only need enough for 1/2 the weight in WLL. 2 chains gets him to 13,200 lbs WLL. A 22,000 lbs coil would need at least 11,000 lbs WLL so he's legal with 2.
    If he was using 5/16 G70 they are good for 4700 lbs so he only needs 3 to be legal. That would get him to 14,100 lbs WLL of the 11,000 he needs.
