'23 W900L Steering Issue
Discussion in 'Ask An Owner Operator' started by OhNoTerry, Jan 1, 2026.
  1. OhNoTerry
    OhNoTerry Medium Load Member
    316
    475
    May 22, 2021
    Well, Happy New Year guys! Starting off the year not so strong, lmfao.
    Anyways, I got to a customer site and while turning, my steering started shuddering/hiccuping while turning. About a 1/16th of a turn each way you start to feel a wall, then it gives, then the wall, and so on and so forth. There is no audible sound, all metal components linked to the steering do not feel bound up, loose, etc. No visible leaks from what I can see, but there was a very very mild wet spot where the line connects to the bottom of steering fluid reservoir. Fluid level is as it should be according to the reservoir tank. It has 240k miles and I have yet to do a service/flush on the steering pump/reservoir.
    Is it likely I'm experiencing a pump failure or did air manage to get into my line? How would I go about releasing air from the system? Simply cracking open the fill cap of the tank? Any other checks I should be able to do without a mechanic to diagnose my issue?
  3. 062
    062 Road Train Member
    6,328
    33,969
    Oct 20, 2013
    Start with changing the filter and if it has grease able u-joints give them a good shot of grease.
    OhNoTerry Thanks this.
  4. Long FLD
    Long FLD Road Train Member
    12,869
    53,848
    Mar 4, 2015
    Was your truck part of the big recall back in 2022? Some gearboxes weren’t assembled correctly and would have issue during slow speed turning.
  5. Ridgeline
    22,720
    123,307
    I had a WS that had issues like that last year (2024), it turned out to be the relief/flow control valve in the power steering pump itself.
  6. OhNoTerry
    316
    475
    May 22, 2021
    I haven’t been notified by my dealer for said recall. Was this for year model 2022’s or built in 2022? All I got was a recall for the belt system on the Atlas seats.
  7. Long FLD
    12,869
    53,848
    Mar 4, 2015
    Banker, SL3406 and OhNoTerry Thank this.
  8. OhNoTerry
    316
    475
    May 22, 2021
    Long FLD Thanks this.
  9. OhNoTerry
    316
    475
    May 22, 2021
    Turns out I wasn't apart of the recall. The issue went away somehow mid drive the next day, but still going to service the steering fluid and see how it goes from there. As someone said previously, seems like a flow valve issue, nothing metal on metal.
