264 Rear Axle Ratio???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by whoopNride, Jan 26, 2013.
  1. whoopNride
    whoopNride Road Train Member
    1,649
    4,998
    Jan 13, 2008
    Miss.
    I have a friend buying his first truck.He has found a Great starter truck that is priced right and in really good condition, 14L Det. It has a ddirect 10spd with a 264 rear axle ratio.
    Now, I have owned many trucks in the last 20 yrs, but have no experience with this axle ratio. Everything I have owned or currently own has been geared from 3.42 to 3.90. I assume the final gear in the transmission is lower than normal to offset this type rear end ratio??? Anyone have any experience, thoughts, advice on a 264 rear ratio ??
    I did some research online, and found that most of the older Walmart trucks were setup this way.
    Advice ???
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,357
    Feb 24, 2012
    yop, it will do wonders for him.
    Last company I had our best fuel mileage was had with DD13's with 10D and 2.64 rears.
    whoopNride Thanks this.
  4. losttrucker
    losttrucker Road Train Member
    1,436
    1,037
    Mar 9, 2008
    greenville,nc
    I have an 05 Columbia with that ratio and let's just say that it SUCKS!! Zero pull in the mountains and city driving with stop and go is a nightmare!!
    Let me add that on the highway cruising is great!!
  5. 25(2)+2
    18,387
    37,066
    Sep 18, 2006
    the road less travelled
    The direct is 1.00 in high as opposed to an OD, the truck I drive now has .74 in high or thereabouts with 10 speeds and supposed to be 3.42. axle but I'm not sure I buy that.
    The direct is supposed to be less internal losses in high than an OD and I'm not sure how much real world difference there is, the final ratio of engine revolutions per distance traveled is close to the same for 2.64 direct as with a 3.42 with .74 overdrive.
    I drove one for quite a while with a 12.7, just needed to be able to use the engine not be governed out to force progressive shifting, that modification made mountain driving horrible.
    WitchingHour and whoopNride Thank this.
  6. MNdriver
    7,985
    4,357
    Feb 24, 2012
    the company I drove for used them in MN, ILL, WI, IA, MO and SD. Occasionally, they'd head to Twin Falls ID.
  7. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,033
    May 13, 2011
    Middle Tennessee
    When you think about it does it really make sense to put an overdrive gear set ahead of an underdrive gear set just because we've been doing it this way for years?
  8. black_dog106
    black_dog106 Road Train Member
    1,768
    1,567
    Mar 29, 2009
    MA
    Cowpie1 recently bought a truck speced for mileage. He has many posts/threads on this subject. I havent read many posts from him recently about his truck. I believe he is very happy with his truck. He did alot of research before specing truck. Iirc, he ordered an 18 speed trans? He will see this thread and hopfully will post or send him a pm.
  9. whoopNride
    1,649
    4,998
    Jan 13, 2008
    Miss.
    Thanks for the posts guys, opinions are what im looking for. the hills-mountains would be my concern.
    I had a 91 Freightshaker back in the day with a 10 over with 3.90 rears, and i really liked that setup.
    I am going with him on Monday to check this thing over. I cant wait to drive it. Hopefully we can put it under a trailer and see what she does.
  10. flc120
    flc120 Heavy Load Member
    916
    121
    Jul 11, 2012
    Miami,FL (yeah i know :( )
    holy crapper batman 2.64 talk about highway geared just dont stop lol...
  11. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    649
    Feb 27, 2011
    Middletown,Oh.
    Yes he has 2.64's and 18 spd. runs around in 17th most of the time, he says he gets excellent mileage.
  • Draft saved Draft deleted
